How do I calibrate my stepper motors with an Openbuilds touch inferface ?
Discussion in 'CNC Mills/Routers' started by Brad Guest, Jun 6, 2021.
  1. Brad Guest
    How do I calibrate my stepper motors with an Openbuilds touch interface ?.The computer is in a different area so how do I load commands onto the touch interface to do it or how do I plug my blackbox controller into the computer but then make the measurements on the CNC ? I see no way to do this
    The wizard is only available in CONTROL. Connect your USB cable to the Blackbox and go for it.
    See
  3. Brad Guest
    th
    This does not answer my question though, How to do I do that when I have the touch controller, the only interaction between my computer & the machine is a USB
    You don't use the Interface. You use a Computer running CONTROL.
    Take the PC to the machine.
  5. Brad Guest
    I have taken the computer to the machine , connected the black box to the computer but the Openbuilds wizard does not allow me to open up the calibration option. They do not high light
    According to the screenshots, you haven't "connected" yet. Please connect succesfully first, to enable the features that require connectivity to a machine. Seatures are grayed out as they are not available until you connect.
  7. Brad Guest
    It’s why it wasn’t connecting that is the issue .did not recognize it . Followed openbuilds instruction on BlackBox to install drivers but the instruction were vague . In the end I found where the box was located & installed the drivers from there . It was not where the instructions said they would be . Now I can maybe get the BlackBox to do calibration
