How to correct XYZ directions
Discussion in 'CNC Mills/Routers' started by Kyung, Sep 24, 2024.
  1. Kyung
    Kyung New
    Hi, I've set up my Stronghold one 1250x1250.
    However, this is how the machine moves. The Y axis is reversed.
    So I did what everyone have suggested, to reverse the Y axis in Grbl setting, $3 Y normal to be reveresed.
    It works fine until here, all xyz directions work in the right way. However, when I press home, the Y moves away from the y trigger switch. How could I solve this?
    Thanks!
    $3 sets jog directions (set to match cartesian standard)
    Then use $23 to tell "where are the switches" - where did you install them. At axis Min or Max end.
