How to round and cut at the same time
Discussion in 'CNC Mills/Routers' started by ArnBee, Oct 2, 2021.
  1. ArnBee
    ArnBee New
    Hello,
    I need your advice because I didn't succeed to slightly rounded and cut at the same time the sides of a plate.
    When I do it, the size of the cut is a little bit smaller than asked.
    The thickness of the plate is 3mm and I use the CMT 765.402.11 router bit (Fraises profilées | CMT Orange Tools).
    Here are my settings in OB Cam.
    Thank you.
    Post a pic of the result please?
    Your screenshot shows a 10mm endmill diameter entered. Is that correct? Wouldnt you want the offset from drawing to be the thinnest section of the bit?
  3. ArnBee
    ArnBee New
    Peter,
    Your answer lets me think that indeed I made a mistake with the diameter ;)
    I'll test it tomorrow.
    Thank you
      File size:
      123.8 KB
      50
