How to use variables in openbuilds macro's?
Discussion in 'CAM' started by Erik HENDRIX 0X, Jan 22, 2022.
  1. Erik HENDRIX 0X
    Is there a way to use variables in an open builds macro, for example to make easy movement calculations based on a variable drill width?
    I have seen some gcode programs declaring variables with e.g. #101 = 8 using them later in e.g. G01 F500 X15+#101 but I can't make it work on my machine.
    You can use the Javacript macro functionality - with it you can even build UIs to enter the values into your variables. See Getting started with Javascript Macros in CONTROL / Library of Macros created by the community
    With string substitution and maths and all the tools you will ever need, much more power than plain gcode.
    Erik HENDRIX 0X likes this.
  3. Erik HENDRIX 0X
    Thanks Peter, helps me a lot. Do you happen to know a way to get user input in some way. Prompt() nor ReadLine() are being accepted.
    See the link above for examples using Metro.dialog to build UIs with input forms.
  5. Erik HENDRIX 0X
    Thanks again Peter. Took me a while to figure it out ... but it works. Appreciated.
