HsmWorks post processor error
Discussion in 'CAM' started by Bowbo974, Apr 3, 2023.
  1. Bowbo974
    Bowbo974 New
    Hello, I tried Hsmworks for my cnc cuts, at first sight it seemed to work, but in reality with the grbl post processor it makes me disconnect from the black box during the operation...
    I tried with gcode on the openbuild interface and I got an error with a gcode block.
    I tried to install the fusion 360 post processor for hsmworks but that does not work, it gives me an error when creating the gcode.
    anyone have a solution? THANKS
      File size:
      350.3 KB
      52
    Contact your CAM vendor and enquire about the correct post to get standard Grbl compatible gcode: Home
    It's up to the CAM vendor to supply posts for industry standard firmwares like Grbl.
    Also see docs:software:overview [OpenBuilds Documentation]
  3. Bowbo974
    Bowbo974 New
    Thank you for the answer, there is a grbl post processor, but it doesn't "work" in reality it works for a while but then the blackbox X32 disconnects
  5. Bowbo974
    Bowbo974 New
