Huanyang VFD will only do 200hz
Discussion in 'CNC Mills/Routers' started by Brealy, Dec 17, 2019.
  1. Brealy
    Brealy New
    Huanyang VFD 220v
    2.2KW Water Cooled Spindle
    I have been over the settings and I just can seem to find the one for this.
    The spindle will only go up to 200hz or 12000 rpms
    Here are some of my basic settings
    PD001=1
    PD002=1
    PD003=400
    PD004=400
    PD005=400
    PD008=220
    PD070=0
    PD141=220
    PD142=9
    PD143=2
    I have also tried to set it up to be controlled by Openbuilds control with the black box but have yet to get that to work ether. I am starting to think I have a bad VFD.
  2. Kevon Ritter
    Kevon Ritter Veteran
    Here are my settings.
  3. Jaim Wolfe
    I'm having this same issue, did you end up having a bad VFD, or get some resolution?
  4. Brealy
    Brealy New
    I just reset to factory and renetered all the settings and it works fine now.
  5. Gofertpc
    Gofertpc Well-Known
    If PD143 is set to 4 pole it will cause this make sure it is set to 2 pole.
