I need help with the Aspire program and milling on openbuilds lead 1010
Discussion in 'CNC Mills/Routers' started by Mateusz Klimczak, Nov 6, 2019.
  1. Mateusz Klimczak
    Hello, I still have a program in addition to fusion 360 on which so far works milling and creating g-code. But I still have the Aspire program and what should I write the program on so that the milling machine can read the g-code to me?
  2. Alex Chambers
    If you are asking what post processor to use with Aspire to create g-code then use "Gbrl (mm)(*.gcode)" post processor.
  3. Mateusz Klimczak
    That's exactly what I'm asking, so postprocessor for Aspire, because in fusion 360 with purchase of a milling machine I got the file "Workbee-duet"
    So I ask if it is similar in Aspire, or if the same can be used for Aspire to work on my milling machine, or is it different, where it will read g-codes on an openbuilds lead 1010 milling machine
  4. Alex Chambers
