Hi everyone. I've had it with my 3D Printed printer causing me vibration and misalignment issues so i decided to rebuild it with OpenBuilds hardware. I've been designing it in Fusion for a bit now and I cannot for the life of my find a solution for my idler pulleys. So far the only options I have found was to either use the idler plates and raise my gantry plates by quite a lot so that the belts will align straight with it (rising always means more chances of vibrations) or use the threaded rod plates. That second option works fine for the X gantry (although it is ugly), but for the Y the plate is too long and I would have to cut it to avoid using 40mm extrusion for the peripheral frame. I want to have a fram that fully touches the table as I plan to enclose it using the frame for ABS printing. Any ideas, suggestions, anything? I'm at my wits end.
If you split that Y 2080 to two 2040 and move it more to edges of buildplate you can hide belt between them (if I understand what you want) and also as second effect you will enhance bottom frame rigidity
Something like this US $738.94 26% OFF|Aibecy CR 10 S4 High precision DIY i3 3D printer Easy to Assemble Filament Run out Detection Resume Printing Function|i3 3d printer|3d printer|i3 3d - AliExpress
