I'm Back!
Discussion in 'CNC Mills/Routers' started by rbrpguy, Aug 30, 2023.
  1. rbrpguy
    rbrpguy New
    Hi Ya'll! For those who may have wondered what ever happened to the high maintenance, old dog Master Cam guy, well I'm back and the old dog learned a new trick! :) I spent 3 days learning Fusion 360 free version (well, enough to be dangerous) and did a simple drill, pocket, contour. Did an air run and watching the read out, seems to be ok. I believe I had mentioned before that I am not a code guy, so I was wondering if you could help me with this (see attached) on line 801, I tell Z to go 1" above work surface. it does, but then goes back to 0 and X and Y go home. What do I change/add to keep Z at 1" while X and Y go to home. Thanks!
    • ARM.txt
      File size:
      21.1 KB
      74
  2. Brian Slee
    Brian Slee Well-Known
    Get rid of the G28 (Return to reference position) command on line 803 and it should stay at Z1
  3. rbrpguy
    rbrpguy New
    Thanks Brian, I will give that a try!
    If there's a G28, its not our Post
    Make sure to use the OpenBuilds Post Processor. No G28 weirdness. Just needs you to Home (Simpler to understand): docs:software:fusion360 [OpenBuilds Documentation]
  5. rbrpguy
    rbrpguy New
    Nope, Z went down to 0 and X and Y didn't go home.:(
  6. rbrpguy
    rbrpguy New
    So I used the Grbl post processor in Fusion 360. So I have to add Open Builds post processor to Fusion 360? If so, how do I do that?
  7. rbrpguy
    rbrpguy New
    Sorry, just saw the link.
  8. Brian Slee
    Ok it is switching to a relative reference with the
    G91. Delete lines 801 802 and 803. After the G90 command add
    Z1
    X0 Y0
    and that should work better
    or you could use the Open Builds Post Proceesor ;)
  9. Peter Van Der Walt
    Yes please recommend our Post - best customer experience and what folks around here will be expecting when providing support. Deleting Gcode is not beginner friendly thanks
  10. rbrpguy
    rbrpguy New
    Ok, got the open builds Post Processor. Please see attached and let me know do I need to get rid of all the verbiage or does the Black Box just ignore this? Also, I don't know what G54 "this relies on homing" means. Thanks!
  11. rbrpguy
    rbrpguy New
    Sorry....here it is
  12. Peter Van Der Walt
    If you use our post you don't have to do anything. We take care of everything.
    You just remember to HOME, SetZero and Run. Standard for all CAMs
    Means DONT FORGET TO HOME :)
  13. rbrpguy
    rbrpguy New
    Excellent. Thanks!
  14. Misterg
    Misterg Veteran
    It sounds like you are sorted now with the Openbuilds POST, but just FYI there is a setting in the default Fusion360 GRBL post processor for 'Safe retracts and home positioning'. By default this is set to the 'G28' option. If you change this to the 'Clearance Height' option, you don't get the machine heading off to where it thinks G28 is at the end of the job (which is what was happening).
    (Of course, if you have defined your G28 position in advance, than this can be a useful option.)
    As I said, just a 'FYI'
    rbrpguy likes this.
