Hello There, I have a problem in the during of CNC milling operation. Sometimes in during of operation mzy software interrupts and machine stoped with a unknown error. I think this error commes of incompatibles' win7 with a new update openbuilds software, but I am not sure. But my question is another, how can I continue to working after that without reject to point of start.
Resuming is accomplished by hand-editing GCODE - ensuring you bring in all earlier Modals, and adding safe-entry moves before the recovery point. Not easy, same reason there is no automated way to do it safely. More often its easier to just start over, or re-CAM to exclude already cut sections. But, rather prevent the stops: see docs.openbuilds.com/blackbox and make sure you checkout section 4.2 and 6.2 respectively as most likely causes
