IOT Switching Relay Power Strip
Discussion in 'General Talk' started by JayJ, May 27, 2021.
  1. JayJ
    JayJ New
    Looking for a 220 volt version of this to use here in Germany. Not sure what I would even search for on amazon. I tried using the English words but that did not give me any results that were even close. Any suggestions?
  2. Rink
    Rink Well-Known
    I searched on amazon and also did not find anything in 220v, only 110v.
    Thx, rink.
    Nothing off the shelf we know off. A good electrician can build you a setup using an opto coupled relay driver and a contactor, but for liability reasons we cannot assist directly
  4. JayJ
    JayJ New
    Thanks. I think I came up with a solution lastnight. I have built something similar for my ambient lighting on my tv that turns on and off via a relay and a usb from the tv. Will see if I can apply the same here. I am assuming it is just a 5volt signal that is sent from the black box that could be used to activate a relay.
    As long as you dont try driving a relay coil directly. Signal is logic level, couple mA max. Can drive an Optocoupler
  6. JayJ
    JayJ New
    Using a small relay I can now control the router/spindle from the control software. Is there a way to have the tool start and stop automatically when I run?
    Your CAM application/post processor should add the commands to your Gcode file. What CAM are you using?
  8. JayJ
    JayJ New
    I use vCarve to create the files and then run them with Openbuilds control
  9. Peter Van Der Walt
  10. JayJ
    JayJ New
    Thanks for the help. Total success. Five dollar part and a 3d printed case has it working.
