Issue after update
Discussion in 'CNC Mills/Routers' started by Mark Rinehart, Nov 18, 2022.
  1. Mark Rinehart
    Hello,
    I installed the new update this morning. After the install I pressed Home All and my Z Axis was reversed. So I went into Grbl Settings and inverted the Z Home. Then that worked as before. The directional control is working properly. When I run the simulation everything looks good. On OpenBuilds and Fusion360. But when I try to run a job the spindle goes up until it hits the Z Axis limit switch and stops the machine. If I invert the stepper for Z the spindle comes down and over to the start point like it should but after that Z is going in the wrong direction for the tool path.
    Any suggestions?
  2. Mark Rinehart
    Also want to add its a Lead 1010 with the BlackBox.
    The g-code where it’s acting up is reads
    G1 Z0 F13.33
    It’s as if the machine is going to Machine Z0 instead of Work-coordinate Z0. All of the axis 0’s are set to work-coordinate on the Machine Control page.
  3. Alex Chambers
    Please upload your g-code file here.
  4. Mark Rinehart
    Line 17 is highlighted when its acting up
  5. Alex Chambers
    Not necessarily the whole solution to your problems, but I strongly recommend the Openbuilds post processor for Fusion.
    docs:software:fusion360 [OpenBuilds Documentation]
    It relies on the machine having been homed as it uses machine co-ordinates for safety moves.
  6. Mark Rinehart
    I'll give it a shot. Thank you!
  7. Mark Rinehart
    Thank you very much Sir.
    That seemed to fix it. Job ran without issue
    Alex Chambers likes this.
