K40 12x24in rebuild (In Original Case)
Discussion in 'Laser Cutters' started by tshilling, Feb 14, 2019.
  1. Stephens
    Stephens New
    Hi,
    Currently building this out of an old K40 case, just wondering what bearing was used in the printed bearing holder?
  2. Giarc
  3. mjtq
    mjtq New
    Hi,
    I encountered the same obstacle. I have everything bought and mounted except the bearing that is supposed to go into the bearing holder. I could not figure it out from the pictures either on replicantfx.com. Has anyone completed this build and/or has information and details on said piece of the build? Thanks.
  4. Giarc
    He has a 3D model available to download. All the parts are visible in the assembly. K40 Rebuild in Original Enclosure (12x24in Cut Area) by Hawking
    File formats available in the Thingiverse files:
  5. mjtq
    mjtq New
    Thanks for your post. I have ordered a 5/16 by 7/8 bearing. Hope it works.
  6. Guy Snyder
    I believe they are using the 608ZZ 8x22 mm 608Z Metric Ball Bearing. Or 608 for short.
  7. _Lauren_
    _Lauren_ New
    Quick question.
    What kind of 20 toothed metal bearing can I use in the place of the 2 printable ones for the 5/16 shaft. Or what can I use to substitute those for metal ones. Im in the materials phase of rebuilding this except on "stilts" so I can operate a rotary and install a mechanical z bed. Ill also be moding the case if not trashing all together since it wont be quite deep enough. That or cut the bottom out to place on top a table with a square basin cut out if it to support this idea
  8. Giarc
    I looked and could not find any.
    I am doing a similar conversion and did not feel good about using 3D printed pulleys. one thought I had was to put the Y stepper n the middle and get a dual shaft stepper. That way I could use aluminum pullies at each end and shaft coupler from the stepper to the shaft. But after mulling it over, I realized I could just build a bigger enclosure out of 2020 tslot and acrylic (or plywood sides) and build a larger enclosure with more cutting area and then use one larger stepper with a shaft coupler and two pullies. You could also do this with the existing plan, but you need more room along one of the Y axis so you would loose cutting area. Another reason for this decision is that I could build it deeper too, and have a rotary axis and z lift bed. Originally I was gong to cut the bottom out of the K40 and in the end I realized all I would have left was the flimsy remnants of the K40 perimeter and the top doors.
  9. _Lauren_
    _Lauren_ New
    I'm now in the building phase. Ive decided to just trash the casing and go for 800x600mm. At this time I'm going to try the 3d printed pieces to see if I like the feel. If not I have a few backup options. Check this post out
    Log into Facebook | Facebook
    Its a k40 laser enhancement group on Facebook that i joined. I decided to take the question there and see what other ideas were out there also. Theres some good advice here also mostly with the idea that you have
  10. Jason32473
    I am attempting this build but I have an issue. I dont see the bearings in the BOM that go in the bearing holder? Also are the V Bearings mentioned on the Y carriage are they the same same the V Wheels in the BOM?
    Read more about this build...[/QUOTE]
  11. Jason32473
    Any luck on finding a metal toothed bearing?
  12. Giarc
    No. I may just put an 8mm shaft coupler on then use 8mm pulleys. I decided against using the original case. I found it would be easier using extrusions for the case because I want space for a rotary axis. I can also go bigger.
  13. Graeme Stevens
    Even at 2023 prices I'm looking at around £100 direct cost for the upgrade. Most of that is extrusion, a piece of mdf, some acrylic and a load of fittings. New mobo is not factored in, I had that to use on the K40 anyway.
    If I buy a new laser head I'll be up to £150 in total. If I factored in the cost of the K40, less than £300*, I have paid £500 (including new mobo) for a 40w laser with a 410 x 640 cutting area. Another £100 will see an adjustable bed. I can't see a comparable machine, let alone a better machine, for less than twice that.
    This, and others, are viable upgrades even if you buy a new K40, but there are loads of second hand ones on ebay anyway.
    Mine is not an exact copy of this, it mixes and matches with some other builds.
    *mine was free, the first one they sent was dented so they sent a second one and didn't want the first one back. It was fully functional and has been in use for almost two years.
