Laser turns on when I power up. Running a program, on whe should be off
Discussion in 'General Talk' started by Ben Glenn, Jan 23, 2025.
  1. Ben Glenn
    Ben Glenn New
    When I power on my LEAD 1010 with a Jtech laser, the laser is on when the power is on. I unplugged the wire to tool head and it stays on. When I run the cnc the first light stays on and the second green light on the Jtech box blinks on and off as it cuts. The laser is staying on during tool path movements and and turning off when it should be cutting. Like when you look at the screen and see the green tool path lines, it is burning those.
    Line 32 is set to laser on.
    I have not modified any gcode.
    The laser is on before it runs code.
    HOW do I flip this signal and where. It obviously responds to signal from the controller, just that the controller is starting it off on fire.
    Thanks for any help. First post.
    That rules out the signal/settings - please contact JTech for assistance
