Latest update-failure
Discussion in 'Control Software' started by Luggnutz3000, Feb 11, 2021.
  1. Luggnutz3000
    Rand a job yesterday without issues and things are great.
    Today I get setup to run a new job and open the control software and get the typical update screen. I proceed with the update and restart the computer. It boots up like normal, but now the control software is missing and I have to go and download it from the site...
    I get it up and run through all of my stepper tests and stuff, load a path and start running the job as normal. About 2 hrs into the run, the prompt to install the new update pops up and at the same time the control software goes into train-wreck mode and destroys the carve.... is what is. I shut it all down and again proceed with the 2nd update prompt and now I lost my control software again... any thoughts or things I can check?
    It shouldnt want to update if you just installed the latest. So something is corrupt in your install
    Uninstall, but also clean up the install directory under AppData or Program Files
    Then do a clean install
  3. Luggnutz3000
    Peter
    That seemed to do the trick, %80 through the run with out issues!!!
    thanks for the help!
