Latest update to control software issue
Discussion in 'Control Software' started by Patrick Lewis, Jun 20, 2024.
  1. Patrick Lewis
    I just updated to the latest version of Control. In the machine settings, I realized that the size settings of my X and Y axis are now swapped for my Lead 1010. Previously, the Y axis was 810mm now it's showing at 730MM which is what the X axis used to be before the update. My X axis is now showing 810mm.
    I don't recall having to change them manually in the past 2 years, just curious if there is a glitch in the program with this new release.
    I'm running Grbl 1.1g as well.
    My question is, can I just change them manually to the correct perameters and save it to my Black Box or is this something that is going to require me to upgrade to the newer Black Box X32?
    Negative, not related
    The only thing that can change settings, is the operator.
    Welcome to review the code changes yourself if you believe it did, find and point out the point in the recent changes that would cause that: Commits · OpenBuilds/OpenBuilds-CONTROL
    Grbl Settings tab > Restore your last good backup. No backup? Then manually but remember to Backup when its good!
  3. Patrick Lewis
    Thanks, I did have several backup files and oddly enough, they all had the maximum travel for both X and Y axis's reversed. I have corrected the settings and saved them to the firmware. Also saved a NEW backup file with the corrected settings.
  4. Patrick Lewis
    Could the Lead 1010 Machine profile be reversed, that's where I loaded the settings from originally?
