Hello everyone, i have a question. Every wheels on axis Y work differently. A Some one have a loose, other wheels cannot move. This od normal? What i can calibrate this? Machine lead1010. Work imo is ok Video https://drive.google.com/file/d/15lwWpe_xSkRDyg8FDPVHIJdlzVqERjjR/view?usp=drivesdk
Wheel preload is adjusted using the Eccentric spacers (Typically most people turn the plate so the eccentrics are on top for easier access, but that is your preference - you can still adjust them from below) Perfect tension is when the wheel just starts to grip. Set it too tight and the wheels will wear down faster, too loose and the machine will have accuracy issues. See
