Lead 1515 high Z mod spacing between X C-beams
Discussion in 'CNC Mills/Routers' started by Allistar, Mar 9, 2021.
  1. Allistar
    Allistar New
    Hi there,
    In the Lead 1515 high Z mod the two X C-beams are placed as close to each other as they can be. The main X gantry and the slave X gantry are touching. This means the two C-Beams are about 45mm apart. It seems to a novice like me that rigidity would be improved if the two C-beams were spaced further apart, say 100mm or 150mm. This should reduce twisting of the Z axis in the Y direction.
    Has anyone experimented with changing this design by spacing the C-beams further apart and if so is there a benefit?
    Thanks,
    Allistar.
