Lead 1515 leaving parts uncarved in pockets
Discussion in 'General Talk' started by smithd16, Apr 15, 2025.
  1. smithd16
    smithd16 New
    I have been running a Lead 1515 for a couple years now. Just recently I noticed that it is leaving lines uncarved and just overall messy in each lettering packet. I am using a 60 degree V bit. Has anyone felt with this yet?
    Thank you!
    something in Z is loose, allowing it to bary height as it cuts.
  3. smithd16
    smithd16 New
    Ok that makes sense. I'll look into tightening everything up with Z. Thank you!
  4. smithd16
    smithd16 New
    Everything has ben checked and tightened with the Z. The problem is still happening. Any other ideas?
  5. Misterg
    Misterg Veteran
    How are you holding the workpiece down?
  6. smithd16
    smithd16 New
    I have it clamped on both ends of a 5/4 x 6” board. It’s been working well for me for the good part of two years.
  7. David the swarfer
    if you can upload the gcode file here we can cross check that for you
  8. smithd16
    smithd16 New
    I have attached the g code file here.
  9. Misterg
    Misterg Veteran
    G Code looks OK to me. It still smacks of something loose, but your workpiece is pretty substantial, so I doubt it's that that is flexing.
    Is the tool sharp? Worth trying a different one?
  10. smithd16
    smithd16 New
    hmmmm... I will put on a new bit and run it. Will report back!
  11. Peter Van Der Walt
    Hold the endmill, give it a firm wiggle (upwards in particular). Ones sense of touch can detect movements (and especially relative movements between components) far finer than the eye can see. Feel if the endmill can move up and down (either inside a buster bearing in a spindle, or by lifting up the router and carriage against the leadscrew due to a problem with the nutblock or stop collars etc, or maybe it just moves fwd/back or side to side and the V-bit wanders off course leaving ridges due to loose/worn wheels, and many other possibilities). Feel for looseness and follow the feeling to find the source...
  12. smithd16
    smithd16 New
    You all were right. I had to tighten up one side where the X axis meets the Y axis. Thank you for all the feedback!
