Lead 1515 Need compatible Spindle mount for new spindle
Discussion in 'CNC Mills/Routers' started by DarthBeavis, May 1, 2022.
  1. DarthBeavis
  2. Giarc
    You will probably have to manufacture your own. The problem with the Chinese spindle mounts is that there are many that look alike, but not all have the same hole spacing. Most that I have seen have a 100mm hole spacing so the holes are too wide apart for the 80mm extrusion. It would be a simple project that could be done with a drill press chop saw, a printed template, and some aluminum plate.
  3. Fifth_rendition
    Just curious if you got this working and if so, what has your experience been in the last year with this here?
