Lead 1515 router/plasma
Discussion in 'CNC Mills/Routers' started by jnsbanman, Dec 29, 2020.
  1. jnsbanman
    jnsbanman Well-Known
    I am in the planning stage as I just ordered a 1515 the other day. I also have a 2.2kw spindle and an Everlast 60 amp plasma cutter on their way too.
    I know it would be best to have a dedicated machine for each but that is not in the cards right now. So I am trying to figure out a a axis that would allow quickish changing from router to plasma and vice versa.
    i am planning on using the floating z for the plasma torch. It wouldn’t be too hard to remove the bump stopper to pull the floating section off and bolt on the router clamp.
    or I was thinking of leaving just enough room
    At the bottom under the floating portion to bolt the router clamp to...
    anyone have ideas or seen or make good systems?
