Lead 1515 vs quenbe rigidity
Discussion in 'CNC Mills/Routers' started by fxdfxd, Feb 20, 2021.
  1. fxdfxd
    fxdfxd New
    Hi guys,
    What model would be more rigid, especially in the Y axis, to use with heavier water cooled spindles, on aluminium or heavy cutting in plywood with round over bits :
    - the lead 1515, with its dual C beam on the Y axis ?
    - the quenbe (actually the incoming killer bee from ratrig) with steel plates, single c beam with 2 MGN15 linear rails.
    -fx
  2. NicoBou26
    NicoBou26 New
    What did you decide? did you go with the lead 1515 or killerbee?
