Lead 1515 y axis stuck
Discussion in 'CNC Mills/Routers' started by Jmallen004, Sep 22, 2022.
  1. Jmallen004
    I have a weird problem. If I attempt to jog my y axis at 100% speed (using the interface and black box) only my right y axis moves. You can see a video of what I mean here
    Jmallen004 likes this.
  3. Jmallen004
    Thank you. I’ll take a look at these this weekend
  4. Jmallen004
    So I seem to have fixed the stalling issue. Between the current adjustments and the speed adjustments, along with a couple of wheels being to tight it moves freely now.
    The problem I am now facing is no matter how I adjust the current, I can not get y1 and y2 to sync speeds. Y2 s consistently slower than y1 by about 2-3 inches.
    Not related to current adjustment.
    It may be that the slower motor has a wiring issue: docs:blackbox:faq-identify-motor-coils [OpenBuilds Documentation]
    Or more likely - a loose grubscrew on a shaft coupler - causing leadscrew or motor shaft to be slipping :)
