LEAD CNC 1010 (40" x 40") Max Feed Rate
Discussion in 'CNC Mills/Routers' started by Scott Thompson, Jan 30, 2021.
  1. Scott Thompson
    Hi All,
    I just put together a LEAD CNC 1010 and I have been experimenting with feed rates. I was just wondering if anyone has determined what this machine's maximum feed rate is? So far I have it running at 3000 mm/min (118 ipm) but I'm not sure how much farther I can go before "strange things" start happening. Any feedback would be appreciated.
    Regards,
    Scott
    You can get it to 6000 reliably, if you spend a little time tuning the Acceleration as well. :)
  3. Scott Thompson
    Hi Peter,
    Thanks for the info … I will test it out. Perhaps you (or others) can help me with another question. I will be making my first cut soon using a 1/4" 2 flute downcut endmill on MDF. My initial research on feed rates are crazy fast (6600 mm/min to 8120 mm/min). Can you provide some feedback regarding this? I am a complete newb in this new hobby.
    Thanks,
    Scott
  4. Alex Chambers
    This is a rough guide for a 1/4" end mill - start a bit lower on the feedrate and increase until it sounds as though the router/spindle is working too hard and back off a bit.
    Speeds and feeds
  5. Scott Thompson
    Thanks Alex,
    The spreadsheet is great!
    Scott
    Alex Chambers likes this.
  6. Nathan Reineke
    How would you go about tuning the feed rate and acceleration? I'm just starting out on the Lead 1010 and am using the touch interface since I dont have access to wifi. I see this forum is from a couple years ago so how has the feedrate and acceleration changed? Is it still 1000mm/min and how would I go about changing it? What can I expect for the acceleration tuning/how would I go about doing this?
  7. David the swarfer
    there is a thread about this going on right now .... Stepper Motor tuning test
