Lightburn open builds controller
Discussion in 'CNC Mills/Routers' started by Rommell1787, Dec 15, 2024.
Tags:
  1. Rommell1787
    Hi
    Anyone have issues using lightburn with a diode laser?
    i have issues wit jobs stopping half way through causing me to set and restart the controller. Very frsutrating. I use LB with my co2 laser and my dedicated diode engraver and have no issues.
    using my cnc for the larger bed size.
    Some photos of console and "busy" when the cnc stops the job.
  3. Rommell1787
    ill have a read.
    Works fine when i am using openbuilds software. No issues with stopping mid job or anything.
    Only happens when using LB
  4. Rommell1787
    Ive noticed after home cycle it goes into "busy" and needs a reset.
    Doesnt do this with open builds.
    Thats good, if so might be a lightburn bug, check in with their support
  6. Rommell1787
    I have posted in thier forum also but arent as responsive as you.
    the jobs do seem to stop at the same point each time ive tried. I have the black box V1.
    Try OpenBuilds CAM as a comparison, if it works with our CAM (Laser toolpaths are available in there) it rules out controller/GrblSettings etc
  8. Rommell1787
    No suprise, it works fine using open builds cam.
    Vid of issue in LB
  9. Peter Van Der Walt
    Did you setup lightburn per docs:software:lightburn [OpenBuilds Documentation] (just ruling it out)
    Console log there looks fine, got to PGM End no abnormal early stop
    Is your CAD file clean (not missing a segment? proper closed polylines etc)
    Betting if you export the gcode and run it with CONTROL it will miss that segment too (toolpath not sending issue)
  10. Rommell1787
    Im more concerned that the machine goes into "busy" even after homing. It doesnt respond to movement unless i reset the device and do not home after.
    I didnt follow that guide but the settings are the same anyway.
    The cad file is fine, i exported the dxf and used it in open builds cam. Again the machine doesnt respond after homing.
    #10 Rommell1787, Dec 16, 2024
  11. Peter Van Der Walt
    But fine in CONTROL right? Does it HOME in CONTROL?
    2 axes machine? $44/45 set correctly?
  12. Rommell1787
    Workbee cnc. attached backup of config
  13. Rommell1787
    Quick update.
    The LightBurn team have had me trying absolutely everything and they are struggling. I can generate gcode in Lightbrun and use CONTROL to run it and it works fine.
    I even tried anoher laptop and the same issue happens. Can the GRBL firmware be updated on the Black Box V1?
  14. Peter Van Der Walt
    Hasn't been any new Grbl releases since 2019 so nothing newer to update to
    Proving that Grbl and a well implemented Grbl compatible host works fine. So issue somewhere in LightBURNs comms code even if they won't admit it.
    Best solution for now then to use CONTROL as the host.
  15. Rommell1787
    Ive let the LB guys know about the firmware. for info i am using a block box V1 controller.
