Looking for help with smoothness OX CNC
Discussion in 'CNC Mills/Routers' started by koenvanham, Nov 27, 2024.
  1. koenvanham
    Hi experts!
    After 10 years of dust I finally found room to setup my Ooznest OX. It has a 1000x750mm bed, a Spark xpro v2 controller board, and 4 NEMA23 steppers. The Y & X-axis are belt driven.
    I have trouble with finding the right setting for a smooth mill experience. See attached video's.
    I use 1/8 microstep for the steppers. The most important GBRL settings I use are:
    Grbl 1.1h
    $0=10 (Step pulse time, microseconds)
    $1=25 (Step idle delay, milliseconds)
    $2=0 (Step pulse invert, mask)
    $3=7 (Step direction invert, mask)
    $4=0 (Invert step enable pin, boolean)
    $5=0 (Invert limit pins, boolean)
    $6=0 (Invert probe pin, boolean)
    $10=1 (Status report options, mask)
    $11=0.010 (Junction deviation, millimeters)
    $12=0.002 (Arc tolerance, millimeters)
    $13=0 (Report in inches, boolean)
    $20=0 (Soft limits enable, boolean)
    $21=1 (Hard limits enable, boolean)
    $22=0 (Homing cycle enable, boolean)
    $23=0 (Homing direction invert, mask)
    $100=107.256 (X-axis travel resolution, step/mm)
    $101=107.256 (Y-axis travel resolution, step/mm)
    $102=200.000 (Z-axis travel resolution, step/mm)
    As can be seen in the vid (and esp. heard in the sound), every step is distinguishable, were you would expect a more smooth operation. It harms the final result, it makes the tool bite the wood.
    Are people here with similar challenges? Are these solvable? Any tips are much appreciated!
  2. Misterg
    Misterg Veteran
    I don't think you're seeing individual steps - The feedrate *looks* very slow and it seems the tool is 'grabbing' at the work, then waiting for the machine to catch up, rather than cutting continuously.
    FWIW: I would try increasing the feedrate by at least 50% and see if it makes any difference. If nothing changes, go up by 50% again, etc.
    What feedrate are you using? (What 'feed per tooth' ?). It needs a *very* stiff machine to run low feedrates smoothly.
    Could be runout on that "DC motor with a collet adapter pressed on" (those motors doesn't have sufficient bearings to be called a spindle)
  4. David the swarfer
    Backlash somewhere, feedrate way too slow, depth of cut too much.
    On a belt drive OX you want to be using more of a 'high speed machining' approach, high feedrate with low depth of cut, high RPM.
    Sharp carbide tools.
    Try this, set the Z higher than the material so you can run the Gcode without it doing any cutting. Is that motion smooth?
  5. koenvanham
    Hi Misterg, David and Peter,
    Thanks a lot for reacting. I implemented both you solutions and right now I'm getting the results I expected! Couldn't believe switching from my 100$ spindle to Makita would make such a difference. Especially since no play was noticeable on the bearing.
    Right now I'm somewhere between 500-1000 m/min, with ~15000rpm and 5/6mm tool. This seems to work fine. Although I think I could even step it up after lowering micro stepping to 2 instead of 8. I turned it down since overheating of my spark xpro2 was causing x-axis to freewheel. Added a fan as well to solve this.
