Losing steps..
Discussion in 'CNC Mills/Routers' started by Davi Lego, Dec 14, 2023.
  1. Davi Lego
    Davi Lego New
    Good afternoon,
    So I have a longmill 30x48 machine new build. I have a X32 controller. I calibrated steps for 8 inch square and carved (60 degree VBit) and its right on. So then I carved another profile (60 deg VBit) for a 16 and 25 square as well. The issue is while the size 8 square is right on (x and y) the 16 and 25 are not, they measure right on in the X but off on the Y. The measurements are 16 1/8 and 25 3/16 in the Y. The x axis is on size for all squares. I thought maybe I was losing steps and ran the job 3 times. It followed the same paths all 3 times. My question is if its skipping steps wouldn't the path change in the Y or is skipping steps exactly repeatable? I also have the Y axis wired in parallel because I have a 4th axis. I turned the current up all the way on the Y originally cause the y axis steppers were stalling. That seems fine I don't have any heat in the steppers when I'm running the jobs. I slowed down the Y axis maximum rate to1200 mm/min also. I also disconnected the ballscrew bearing so I could move the x carriage back and forth. No binding or slop very smooth motion. I barely had to adjust the backlash and moves smoothly no play. It appears to lag in the Y briefly when it goes from x to y in the corner of the squares. Not sure whats going on.
  2. Alex Chambers
    If you lose steps you don't get them back again. A square or circle would end up not lining up when it got all the way round. Slowing down for corners is normal.
    Re-calibrate your Y axis over the longest distance you can accurately measure.
  3. Alex Chambers
    PS, I don't recommend making a cut to calibrate - that includes any backlash and tool deflection into the calculation. Use the V bit as a pointer for the measurements. Once you are sure you have your steps/mm correct then a shallow cut will indicate if there are other problems.
  4. Davi Lego
    Davi Lego New
    I calibrated initially with a steel ruler at 8 inches which turned out great for the profile carve. If I readjust for a longer measurement now won't that then throw it off at the 8 measurement? I have a good 8 inch square now but the 16 and 25 are off. I don't understand how it can be right with one and wrong with the others. You would think it would be off a bit but 3/16? I'm not trying to be difficult I'm just trying to understand whats going on.I appreciate your input and thanks for helping!
  5. Alex Chambers
    Explanation in the link below. Don't calibrate with a cut - that includes other variables like backlash and tool deflection. Our leadscrews are not "perfect" - deviation is very small but it does exist. Calibrate your steps/mm first without making a cut. If a cut after that is not accurate it is caused by something else.
    Calibrating your cnc
  6. Davi Lego
    Davi Lego New
    OK, I will read it and recalibrate, thank you!
  7. Giarc
    At 8 inches, there may not have been much of an error to see visually. It is also way too short of a distance for calibration. In that short of a distance it may be hard to visually see that it is off. Over 30 inches, you will definitely see it. For example, when I set mine up, I tested over a distance of 1000mm and my machine went 1000.3mm. I would have never noticed that error at 200mm (8 inches). The longer you calibrate over, the more accurate it will be.
  8. Davi Lego
    Davi Lego New
    Thank you for your input and I'm working on that methodology now. Have a great weekend!!
