M2 Program end - unwanted behaviour for servo
Discussion in 'Control Software' started by Elias Heuninck, Jul 29, 2024.
Tags:
  1. Elias Heuninck
    Hello,
    I have an Acro 1510 with a Blackbox that I use as a pen plotter where a servo does the pen movements. I turn SVG's into Gcode with Sameer Puri's SVG2Gcode website: svg2gcode. This gcode generator always inserts 'M2', the 'program end' command, after the editable program end sequence.
    The pen plotter reacts to this by moving the servo to the 0-position (pen down). This is not ideal for me and I'm wondering if there's a way to change the interpretation of the M2 command, ignore it or exclude the servo for example.
    Elias
    The behaviour is technically correct. M2 should disable the servo signal, and the servo should return to 0 position when the signal is stopped
    Best option, ask the CAM developer to make M2 optional (little tickbox somewhere in the UI?) Issues · sameer/svg2gcode
    Alternatively change pen mount so 0 is pen up and positive positions are pen-down
  3. Elias Heuninck
