Manual Mill To CNC Conversion
Discussion in 'CNC Mills/Routers' started by Brian Pierson, Sep 8, 2020.
  1. Brian Pierson
    I was wondering if anyone had used the Openbuilds electronic components to convert an existing manual mill over to a CNC mill that could use the openbuilds interface? I have a Craftsman Mill/Drill that is begging to be replaced but I figured why replace it if I can convert it?
  3. Rob Taylor
    I do have a manual mill conversion build thread here: Grizzly G0758 Benchtop Mill Conversion - may have some commentary or considerations that might help.
    If you don't want the more advanced features that I was/am interested in- encoder support, auto toolchanging, etc- then grbl will totally work as a basic 3-axis mill control, and the base Openbuilds CNC Electronics Bundle (above) with NEMA23s should work fine for most benchtop machines (I oversized my motors for reasons I think I addressed in the thread).
    My build's still in progress- wasn't gonna put the glass scales back on because technically they shouldn't be required, but now in the process of actually doing so because of some positional inconsistencies- and it'll get an update hopefully before too much longer because I've finally torn myself away from what feels like 6+ months of Fusion 360 with no machines I'm happy to actually perform the work on. :ROFL:
  4. Brian Pierson
    Thank you both for the input! I've already got the mill broken down and am doing some homework on ball screws. Looking forward to getting this going.
