Maybe obvious but I've got to ask Long X and shorter Y
Discussion in 'CNC Mills/Routers' started by By5260, Jan 20, 2023.
  1. By5260
    By5260 New
    Researching to decide which cnc router will work best for me. I'm really liking the Open Builds 1515 but I'm concerned with the space needed. Is it possible, or even a good idea to build one with a wider X axis than the Y? I want to be able to run a door through it (3068) and engrave on the rails. I've read a little about tiling but I'm not sure this design is ridged enough. I'm thinking something in the 1500 x 600 range. I want it to utilize lead screws for the drive. What's your thoughts?
    The design is fine for tiling. But I probably wouldn't go less than 1500x750 as that'll leave you 22.5" usable in the Y direction. The longer you make the Y-axis the more accurate it will be with tiling as it will allow for a longer guide edge. 1500x1000 should even be a consideration.
    Whatever you decide, contact the OpenBuilds Parts Store to get a price. Custom sizes are no problem for them.
  3. By5260
    By5260 New
    I can't tell you how much I appreciate you taking the time to reply. It gives me the assurance to move forward. I like your suggestion for 1000. I'd have room for that.
