MGN12C
Discussion in 'CNC Mills/Routers' started by MAFFPL, Apr 10, 2022.
  1. MAFFPL
    MAFFPL New
    Hi. Can you advise if 12mm linear guides with MGN12C carriage work for small cnc plotter with Nema 23 3Nm motors? It will mill aluminum and steel.
  2. that-jim
    that-jim Journeyman
  3. DarkPenguin
    DarkPenguin Well-Known
    Yours uses the MGN12H carriages, right?
    Those rails were stupid expensive compared to the HGR20s. (And the 20s where cheaper than the HGR15s.) Extra carriages were cheap, tho.
  4. JustinTime
    JustinTime Veteran
    How small is small. If it's small enough the 12mm may be OK since the bigger the rail the bigger the machine has to be to accommodate it.
    MAFFPL likes this.
  5. MAFFPL
    MAFFPL New
    It will look like the one from aliexpress, a 400x250 aluminum work table with a metal base, and a frame made of a 60x60mm steel profile.
  6. MAFFPL
    MAFFPL New
    Such a size and pattern of operation. for this engines 3 Nm.
