Miror, black box? fusion?
Discussion in 'CNC Mills/Routers' started by bardel, Apr 7, 2024.
  1. bardel
    bardel New
    Hello and thanks again for your previous help.
    My worckbee works but I hava a litle problem.
    the projects carve in miror like there was a 180 degre rotation on the axe "x".
    How resolve this problem pls?
    Alex
    Rotation or Mirror?
    (Title says one, post says another)
    Mirrored is simpler (Grbl Settings tab > $3 Direction Invert > Flip switch for offending axis
    Rotation could be both X and Y need Direction Invert,( or you wired X to Y)
  3. bardel
    bardel New
    With image it will be easier perhaps? :)
    the first image is my part
    Test by jogging. Jog X+ > did toolhead move right? If not. Correct $3 in Grbl Settings
    Same for Y etc
  5. bardel
    bardel New
    It's not that, when I jog + the axes go to + and the right
    Is it possible that it is due to the direction of extrusion when I create my part with solidworks?
    #5 bardel, Apr 7, 2024
    CAD/CAM would look wrong in the preview. But post files for review
  7. bardel
    bardel New
    Hello.
    For this project the files are :
    Looks correct to me.
  9. bardel
    bardel New
    Oui but it makes that
  10. Christian James
    Christian James Journeyman
    Still looks like Y axis is inverted.
    Misterg likes this.
  11. bardel
    bardel New
    yes but why? :)
    and how correct that?
  12. Misterg
    Misterg Veteran
    Because it hasn't been set up correctly??
    Does the spindle move away from the front of the machine when you jog Y+?
    If not, the Y axis is reversed.
    Corrected by setting the direction invert mask in the GRBL settings ($3 as Peter posted above) - Go to the 'Grbl Settings' tab in Control and the settings for each axis are there alongside the $3 key.
    Restart Grbl after making any changes, just to be sure.
  13. Peter Van Der Walt
    Then refer earlier advice:
    Flip the offending axis (looks like its flipped on Y)
    So, what about jogging Y? Does Y+ move the Toolhead to the Rear of the stock? (If not, invert)
  14. David the swarfer
    jog X+ must move the tool right relative to the work
    jog Y+ must move tool away relative to the work
    jog Z+ must move tool up away from work
    yes, it is possibly you did something 'interesting' in solidworks, check the setup origin
