Motor Issues
Discussion in 'CNC Mills/Routers' started by Hassan Alhulayli, Jul 9, 2023.
  1. Hassan Alhulayli
    I have problem with the motor my cnc belt driven I set everything but x axis and y axis are stuck they doesn’t move what should I change to make it move
    There is attached file for the problem
  2. Hassan Alhulayli
    My machine is custom machine 1500mm*2500mm
  3. Alex Chambers
    The first question (there will be others when we know the answer to this) - what controller are you using with your machine?
  4. Hassan Alhulayli
    Did you remember to load our recommended machine profile (CONTROL > Grbl Settings tab > Select machine from the list > Save and reset when prompted). It has a Custom option that sets the most important values for you. Start with a known working profile then customize from there
  6. Hassan Alhulayli
  7. Hassan Alhulayli
    Now it worked I tried so chose from the list and I modified on the black box it self I chose mode 1 and correct ms value to 5.3
