MPCNC and Blackbox x32 and Auto-Squaring
Discussion in 'General Electronics' started by Xafod, Aug 1, 2023.
  1. Xafod
    Xafod New
    My name is Allen Morrow and I built my MPCNC Primo out. After playing with it for a bit, I wanted to change the controller out to the Blackbox x32. I have it all mounted and mostly wired up but I have a question. How do I configure the controller to do Auto-Squaring using the limit switches?
    You can compile grblHAL using the grblHAL Web Builder:
    1) Wire up the 2nd square-axis switch in parallel to Z (As XY homes seperately from Z, the Z input can be used to detect X2/Y2 switch)
    2) Configure an AutoSquare option (X or Y as needed) in http://svn.io-engineering.com:8080/?driver=ESP32&board=BlackBox X32 and flash to the controller
  3. Xafod
    Xafod New
    Your awesome!!! I will tweak it when I get home today from work.
    What are your thoughts on having min and max limit switches?
  5. Xafod
    Xafod New
    Do you mean to wire it like this for the auto squaring?
    You can't square two axes with the BlackBox. Only one. X or Y. Building the machine squarely might be much simpler
  7. Xafod
    Xafod New
    ahhhh would it be better to to use the limit switches as homing instead of squaring?
    Definately. Autosquaring is hard to do right - and ultimately - fixing a machine that was built weakly, or out of square in the first place. Using the motors to pull a skewed frame back into square, not ideal. "Workaround" not recommended... Build it properly: Tramming: A generic guideline
