My CNC machine is cutting parts wrong
Discussion in 'CNC Mills/Routers' started by JohnPL, Apr 13, 2023.
  1. JohnPL
    JohnPL New
    I use Builds Controller on a Mac to control my Millright Carve King.
    It has worked perfectly until today.
    After cutting 60 parts perfectly, I took a break, leaving the computer on and Carve King breakout board on.
    After the break the parts were wrong; each part is wrong in a different way - no two parts are alike.
    The discrepancies are small - about 1mm.
    The problem seems to always be in the Y axis. For instance, when cutting a trough using multiple roughing stepdowns, one stepdown will be correct, and the next incorrect.
    Any ideas what could cause this issue?
    I'm using Builds Controller on a Mac. It's worked well for months until today.
    Thanks for any advice.
  2. Alex Chambers
    Most likely a mechanical issue - check for something working loose such as the grub screws in a motor coupler.
  3. JohnPL
    JohnPL New
    Thanks Alex.
    I found this post that gives similar advice:
    But, when we see this issue, its usually mechanical, and then usually: setscrews slipping on motor shaft, leadscrew side, or pulleys shipping on motor shaft (you didn't mention what machine you have, so mentioning both) - for fear of stripping people undertighten the grubscrews.
    If those are tight, gripping the endmill and giving it a wiggle will help you see what else is loose / badly adjusted
    So yesterday I started tightening the setscrew in the motor coupler. As I was doing that, the coupler came apart - so that's clearly what caused the issue. Photo attached.
    Thanks again.
    Alex Chambers likes this.
  4. Alex Chambers
    Glad you found it.
