Nema 42 with BlackBox x32
Discussion in 'Motors' started by Katy, Jan 24, 2025.
  1. Katy
    Katy New
    BlackBox can do max 3.2A RMS, so those motors will be quite underpowered on it.
    External drivers not supported (BlackBox is a plug-and-play system with onboard drivers)
  3. Katy
    Katy New
    Thank you. Can the pwm, tool, and other inputs not be used to receive a signal from a driver? If not, is there any way to modify the blackbox with a more powerful driver?
    #3 Katy, Jan 24, 2025
  4. David the swarfer
    there is a way to use external drivers, but you will need a fair bit of electronics know-how to do it.
    maybe look at Clearpath units? solves the motor + driver questions, step and direction inputs for easy interfacing. you will need 2 power supplies though, one for the higher voltage Clearpath and one 24v for the rest of the system.
