New Lead Screw struggling to go through Nut block
Discussion in 'CNC Mills/Routers' started by Wendel Clement, Apr 4, 2024.
  1. Wendel Clement
    Hello Forum,
    I recently had an accident which bent my X Axis lead screw. So I purchased a new lead screw which I have since received. Only issue now is that one of my two existing nut blocks on the X axis is not taking the new acme screw easily. I have managed to get it through using a vice-grip and a soft cloth but it is not screwing freely and is way too tight I assume even for my High torque NEMA motor.
    Are there any tricks that I need to try or should I just buy a new nut block. As I said, one of them screws in freely, its just the other one which I am having this problem.
    Any advice would be greatly appreciated.
    1) Apply some Dry/PTFE lubcricant
    2) spin it in and out of the nutblock with a cordless drill a couple times to help the nut bed in.
    Unless the screw was from a 3rd party, then return it. Our screws are made to match our nuts
  3. Wendel Clement
    Yep, that worked. Thank you.
  4. Wendel Clement
    Got the screw from one of your resellers here in the UK, so I would assume that it is yours. But I stand corrected. My only challenge now is that I am going to try to reinstall the Nut-block onto the X plate without removing the c-beam. I guess its all part of the fun.
  5. Wendel Clement
    Hello,
    Can you please let me know if this will work as a temporary solution? I got my X axis Lead screw to thread through the nut blocks but I can't get the tension nut to screw onto the lead screw from either end. But I had a spare 8mm lock collar so used it to replace the tension nut. I have managed to get a good tension. It has so far worked fine without a load, but I thought that I ought to check before doing a real job run. Both a new lead screw and tension nut are on order but I need a temp solution as I now have a backload of projects to machine.
    Thanks in advance for any feedback.
    #5 Wendel Clement, Apr 4, 2024
  6. Christian James
    Christian James Journeyman
    Well, lock collars were used before tensioning became fashionable, so should be ok.
    Wendel Clement likes this.
  7. Wendel Clement
    Thank you. Well I took the punt and it seems all fine.
