New to Cam
Discussion in 'CAM' started by Ian Rusch, Sep 2, 2023.
  1. Ian Rusch
    Ian Rusch New
    Hi
    I am new to Openbuilds Cam
    When I try to open a .DXF file I have created in Turbocad I get this message
    " an unknow error occured:Type Error: cannot read propertries of undifined (reading 'color')
    Can anyone help me with this error so I can get started.
    Ian R
    Australia
  2. Alex Chambers
    Are you converting all lines to polylines and saving the dxf as an R14 version?
  3. Ian Rusch
    Ian Rusch New
    Hi Alex
    Thank you for that
    No I was not doing that but will give it a try
    I have been using Estalcam and it accepts my files from Turbocad with no problems
    Alex Chambers and Gary Caruso like this.
  5. Ian Rusch
    Ian Rusch New
    Thank you for the reply
    will see what Turbocad offers for this
  7. Ian Rusch
    Ian Rusch New
    Hi again
    my CNC Plasma is a DYI unit I built my self
    I have been using Mach3 and in there you can calibrate the axis with the number of steps per mm etc.
    How do I do this with the Openbuilds Balck box
    Ian R
  8. Alex Chambers
    If you are using Openbuilds Control there's a calibration wizard, but calibrate over the longest distance you can accurately measure. The pdf explains the theory, the wizard (see the video in that link) makes it easy by doing the sums for you.
    See Calibrating your cnc
    #8 Alex Chambers, Sep 5, 2023
  9. Ian Rusch
    Ian Rusch New
    Hi
    me again
    my home built CNC plasma cutter uses NC limit switches so if any wire breakes etc it goes into error.
    I see Openbuilds uses NO switches, can this be changed to use NC switches.
    Ian R
    Yip see $5 Limits Invert in Grbl Settings
  11. Ian Rusch
    Ian Rusch New
    Thank you
    your support on this forum is amazing
    I am so glad i purchased the Black Box
    My 24 volt power supply has finaly arrived so i will now be able to power up the controller and see how it all works
    Thanks once again for all your support
    Ian R
  12. Ian Rusch
    Ian Rusch New
    Hi
    me again
    my replacment Blackbox X32 has arrived so I am back trying to set things up
    still having issues with opening a DXF file from Turbocad, have tried to tidy it up in Qcad but still will not work
    comes up with undifined error
    could some one have a look at the attached files for me please and give some idea why I can not open it.
    the Welding Clamp.DXF is from Turbocad, I cam open this in Estlcam and run the Gcode in Mach3 and it all works.
    Ian R.
  13. Giarc
    You probably already know this, but if it opens in Estlcam, you can save the gcode using a grbl post pricessor.
  14. Ian Rusch
    Ian Rusch New
    thanks
    I did not know that
    can you explain more please
  15. Giarc
    I am way over a thousand miles from my computer so I cannot do any screenshots, but it is in the Set-up portion of the software where you can choose the grbl, mach3, etc. It is also where you can decide if you zero at the machine bed, or the top of the work piece.
  16. Giarc
    If you have not done so yet, under "Setup" select "CNC programs/ post processors, then select "Presets" and choose grbl.
