newbie plasma cutter questions
Discussion in 'Laser Cutters' started by dr_chops, Nov 13, 2021.
  1. dr_chops
    dr_chops New
    hi all
    I'm looking at starting a plasma cutter build, I want to automate a hand held cutter for better accuracy and more complex profiles. I can deal with the mechanical side of the build pretty well but my questions are how are the profiles programmed into the machine for cutting and does the programming determine the start and stop of the torch? how much coding do I need to do or is that more the nesting side?
    I usually out source my profile cutting and haven't really looked into the technical aspect of cutting
    cheers
    Lucas
    Checkout
  3. dr_chops
    dr_chops New
    Awesome thanks. I think I’ll get the openbuild 1515 as a base and run from there
    cheers
    Lucas
  4. dr_chops
    dr_chops New
    hi all ive pulled the trigger on the 1515 and a big boy plasma cutter but I'm struggling to find any info on how to integrate the torch into the machine can anyone link my some videos
    cheers
    Lucas
    See docs:blackbox:connect-plasma [OpenBuilds Documentation]
    See
  6. dr_chops
    dr_chops New
    thanks I swear I looked there must of had a man look
    cheers
    Lucas
  7. dr_chops
    dr_chops New
    why can't I find the touch off sensor in the open builds store?
    sorry
    Lucas
    See: XYZ Touch Probe Plus
    dr_chops likes this.
  9. dr_chops
    dr_chops New
    i see thanks peter. i saw what must be the old version on the diagram you sent me which is what confused me the most
    cheers
    lucas
    Oh you mean the Limit Switch on the Plasma wiring page? Sorry: see Xtension Limit Switch Kit
    Though you meant our Touch Probe from the way it was worded :)
