Hi, It's been a few days since I can't connect to the machine (OpenBuilds Control). The latest version is installed and it works. I tried to reinstall it but it doesn't work, if I import the Gcode it's fine. What can I check again? Thank
1) Did you allow CONTROL through the Windows Firewall 2) make sure you are on the latest version of CONTROL 3) Make sure your computer can do external DNS lookups (nslookup mymachine.openbuilds.com should return 127.0.0.1)
I use Linux. I had transferred a Gcode and it was doing the job. At the and he never reconnected: I have not changed any parameters The version is the last, no make change at Linux system
In the browser, open Devtools > console and refresh the CAM page - might see some clue as to why the ajax request to https://mymachine.openbuilds.com:3001 fails
It's a mistery. I clicked by mistake on the link https://mymachine.openbuilds.com:3001/ The control page has opened and OpenBuilds CAM has connected. Closed the page and launched Openbuild Control pre-program now it's fine, connect and transfer Gcode. I don't understand, but now it works!
