No Firmware Upgrade possible
Discussion in 'Controller Boards' started by Sebk, Aug 6, 2024.
  1. Sebk
    Sebk New
    Hello,
    Using a Blackbox X32 on linux ubuntu with CONTROL and i'm desperatly trying to upgrade the box firmware but receive this message :
    [ Firmware Upgrade ] [Starting...]
    [11:41:56] [ disconnect ] PORT INFO: Port closed
    I guess there is something i have missed somewhere ...
    Easiest to use a Windows PC
    On linux you'll want to look at your python/pyserial dependencies etc
  3. Sebk
    Sebk New
    Sweet answer for a non windows user ... But thank you anyway
    It do not work even on a windows station ...
    Is there any way to hard reset the board ? maybe use the SD card on board ?
    Got some strange info on it
    Processor: ESP32
    CPU Frequency: 240 Mhz
    FW version: 1.1f(20220325)(ESP32)
    Driver version: 220327
    IDF version: v4.3.2-555-gb4ef1b80a2-dirty
    Board: BlackBox X32
    Free memory: 110364
    Baud rate: 115200
    IP: 192.168.2.102
    Data port: 23
    Web port: 80
    Websocket port: 81
    WebUI version: 2.1b52
    Did a quick test with screen record, works fine
    We don't provide tech support for Linux. As a linux user you sort of accept the need to manage your OS's permissions, dependencies, etc. Advanced OS for advanced users. Run from a terminal and check the logs, see whats missing and resolve it. We can't assist. CONTROL just calls the standard python esptool for you.
    If the board's been damaged you'd see the tool running and be unable to find the device (will tell you so in the log), your blank log indicated a more IT like issue. You didn't include the windows logs.
    Pretty standard grblHAL $I output there, but wondering if you are doing the bootloader step: Assuming you are following the docs? docs:blackbox-x32:firmware [OpenBuilds Documentation] and docs:blackbox-x32:faq-bootloader [OpenBuilds Documentation] if the relevant error as shown in the 2nd page appears in your logs
  5. Sebk
    Sebk New
    hum heartbreaking but i find an old windows where everything goes well
    Thanks for support :)
