No supported firmware
Discussion in 'Controller Boards' started by AlbinoPolarBarr, Dec 2, 2020.
  1. AlbinoPolarBarr
    OpenControl Black Box *
    Today I was doing a simple homing check and once my machine hit the z axis limit switch all things stopped. Froze couldnt do anything and as the title states I now have the firmware alarm.
    I removed all wires and left just the usb, tried to reconnect with no success.
    I am able to flash with the wizard with not issues though so that tells me that the usb ports are working correctly which is interesting.
    Notable Mentions :
    - The "motors enabled" and "tool on" leds stay lit at all times.
    - The usb led flashes 3 times when attempting to connect to bbox
    - Used a different usb port and cable with same results
    - When I plug the usb in you can hear a relay clicking on
    - Using MAC OS with no issues in the past
    Its almost like its stuck in a state and cant start reconnect.
    I checked the wires and all looks to be ok
    Any Suggestions??
    HAALLLPPPPP
    #1 AlbinoPolarBarr, Dec 2, 2020
  2. ljvb
    ljvb Well-Known
    Knowing which controller you have would help.
    AlbinoPolarBarr likes this.
  3. AlbinoPolarBarr
    Yup! You're right. The OpenControl Black box
