No tabs
Discussion in 'CNC Mills/Routers' started by Greg Peachey, Jun 10, 2022.
  1. Greg Peachey
    Hi can some one enlighten me what I'm doing wrong
    I'm trying to add tabs but it will not generate them
    I'm milling 9 mm marine ply
    thanks Greg
    The file in question does not have any straight sections longer than the 4mm tab width you want to use - where it can place a tab. Tabs can only be added to straight line segments.
  3. Alex Chambers
    If you use masking tape and superglue to hold the workpiece then you won't need tabs.
    Good idea yes! Different workholding techniques for different jobs - and matching the right kind of workholding to the job in question
    Here's how to do the tape/CA method:
    docs:tips:ca-glue [OpenBuilds Documentation]
  5. Greg Peachey
    Thanks guys that explains a lot and a great tip Alex will be using for now on
    Cheers Greg
  6. Evilspawn
    Evilspawn New
    I have found IPG double-sided tape to work very well. It's a tad thicker than standard DS tape, and sticks very well to the piece and waste-board, yet comes off cleanly.
