Not getting full servo travel
Discussion in 'Controller Boards' started by base1379, Nov 29, 2020.
  1. base1379
    base1379 New
    Hello,
    I'm setting up a servo (Tower Pro SG90 9g micro servo) with the blackbox.
    I've successfully flashed the 2axis + RC servo firmware.
    I've removed the relay jumper.
    After calibrating the servo with 0 corresponding to pen up and 255 corresponding to pen down, i'm only getting about 80 degrees of travel. The servo is capable of about 200 degrees.
    I've used this same servo with an arduino before and was able to get the full travel.
    Am I missing a setting somewhere?
    thanks,
    Wolfgang
    Check your value in $30 (Max RPM)
    0-255 gcode, needs $30=255
    base1379 likes this.
  3. base1379
    base1379 New
    That was it! Thanks Peter for the ridiculously fast response!!!!!!!!!!!!!!!!!!!!!
