OB's Control Software
Discussion in 'CNC Mills/Routers' started by KCollins, Oct 4, 2024.
  1. KCollins
    KCollins Well-Known
    So I am helping a guy set up his machine and we are using OB's control software. He set it up and it is working but when he zero's his machine and then jogs on his x or y 1 inch it only travels 0.039 of an inch? Why is that?
    Wizards and tools > Calibration - his steps per mm is off - the Grbl Wiki is a must-read Grbl v1.1 Configuration
    Or you accidentally set $13=1 (Should be $13=0)
    #2 Peter Van Der Walt, Oct 4, 2024
  3. KCollins
    KCollins Well-Known
    Here's a question for you Peter. sometimes. not all the time... I will jog my machine and instead of it jogging one inch it jogs two. Why is that?
    Lots of possibilities, first guess: wireless mouse/keyboard used for sending jog command / clicking jog button?
  5. KCollins
    KCollins Well-Known
    Okay... he recalibrated and it is still reading 0.039 of an inch when he jogs an inch. $13 is set to 1 at the moment.
  6. Christian James
    Christian James Journeyman
    As Peter said, $13 should be set to zero.
    0.039" is almost exactly 1mm.
  7. KCollins
    KCollins Well-Known
    Yep that fixed it... Thanks guys
