Openbuild 1.0.370, Pause, Stop, Abort
Discussion in 'CNC Mills/Routers' started by Tahir@NY, Jan 27, 2024.
  1. Tahir@NY
    Tahir@NY New
    Hello,
    When in the middle of the Job, I happen to pause, stop or abort an operation or project. The software completely forgets the initial work zero. It just randomly goes to some coordinates and often z just plunges into the material.
    I am wondering what am I doing wrong. I am running Windows 10
    Thank you for your help.
    #1 Tahir@NY, Jan 27, 2024
  2. Alex Chambers
    More details please - what cad/cam software and which post processor.
    Are you homing your machine before running the job?
  3. Tahir@NY
    Tahir@NY New
    The software I use to generate gcode is vectric vcarve and processor I use is GRBL MM.
    I home the machine before I run the job. Yes.
    The job runs fine if I dont have to abort or stop. The work home position gets lost if I happened to abandon or stop in the middle of the job.
  4. Alex Chambers
  5. Tahir@NY
    Tahir@NY New
    Thank you. I will try that and report back.
    No, Grbl HAS TO forget the position on Aborts. Abort is sudden and instant. Position is lost. You HAVE TO rehome.
    Pause won't, stop shouldn't. But look into your workflow.
    Anyhow. Loss of position is never lost. Rehome and continue. Homing always reestablishes coordinates
