Openbuild Blackbox Controller software locks up
Discussion in 'Control Software' started by Ducksy, Oct 26, 2020.
  1. Ducksy
    Ducksy New
    Good Day. If I have an arbitrary program lock up, I can only reset the software by rebooting my computer, the software will not respond to any commands unless I do so.
    Any ideas of whats going on.
    Thanks David.
    - Try a different computer
    - Update all drivers (It needs good WebGL graphics support)
    - Post specs of your PC
    Alternatively, use the Troubleshooting > Application Diagnostics menu to disable features to make it work better on a slow computer:
  3. Ducksy
    Ducksy New
    Yes thanks for the reply Peter, I am running a dedicated Desktop with Win 10 with AMD A6-6400K APU with Radeon (tm) HD Graphics 3.90 GHz, along with 4.00 GB Ram.
    I think the computer is quite capable of running the control program ?
    Your David.
    Should be, so check drivers updates, conflicting applications, etc.
    Run a few Burn in tests with Benchmarking software to see if the hardware maybe locks up after some processing (usually a sign of power or thermal issues)
