OpenBuild Cam Questions
Discussion in 'CNC Mills/Routers' started by William Campbell, Jan 7, 2021.
  1. William Campbell
    Why is it when I input DXF file from shaper 3d and I set Toolpaths to cut a outter square panel with an outer offset its telling me I have a open vector, this is what it says,,,,,,
    NB: You cannot use Offset operations on Open Vectors, you can try to use "No Offset" operations, or repair the file first
    can someone help, thank you
