Openbuilds cam and V Groove Solid Carbide 90 Degree bit
Discussion in 'CAM' started by William Boone, Jan 18, 2022.
  1. William Boone
    Hello all! I'm an Openbuilds newbie and wanted to use the V grove Solid Carbide 90 bit with Openbuilds cam but couldn't figure the correct setting to go into the toolpath for the endmill/pen diameter. Is it possible to use that bit with Openbuilds cam or do I need to seek another solution? And are there any other settings or changes I should make for that bit, if I can use it there? Thanks!
    Depends what you intend doing with the v-bit?
    If you just want to make a v-shaped groove along the lines in your CAD file (for example engraving) you'd use the No Offset CNC toolpaths (not offsetting by any endmill diameter - just follow the line)
    If you were looking for proper "V-Carving" - ie the advanced CAM process to square off engravings and add 3D features, you'd need to look at Vectric Products - OpenBuilds Part Store
  3. William Boone
    Thanks Peter! I'll try with No Offset.
