Openbuilds CAM - DXF Scale issue?
Discussion in 'CAM' started by rcgleason, Mar 26, 2025.
  1. rcgleason
    rcgleason New
    Hi,
    New to OpenBuilds. I am planning a 1000mm x 2000mm Draw Bot for patterning large canvas projects.
    Here is a screenshot from the CAM software using a PolyLines 2013.
    The "LITTLE TINY" thing you see to the lower right is actually a piece of material that should be approximately 3 feet by 2 feet... The grid you see is 1000mm x 2000mm, as I set up in the cusom Acro Drawbot settings.
    why is it soooooo tiny 13 mm x 60mm ?????
    I am also including my DXF
    exported your DXf in millimeters?
  3. rcgleason
    rcgleason New
    Yeah. .. mm -vs- in on the DXF ...
